Displays the Fabric Attach port configuration.
| ports | Specifies the port to configure. |
| port_list | Specifies a list of ports to configure. |
| all | Specifies configuring all ports in the system. |
If no mapping is present, no information will be displayed for the client type.
Use this command to display configured Fabric Attach ports.
The following example displayes configured Fabric Attach ports:
# show fabric attach ports 25 Port Disabled Managment Forward Authentication --------- -------- ----------------- -------------- 25 Yes Off Disabled
This command was first available in ExtremeXOS 31.3.
